Root Help, phone wont ring
Targaryen
Member
I, my widest evo is running decks reloaded, has been for months. One day her ringtones changed and then went from there to not ringing at all. I tried everything I could think of, then went so far as to wipe and refresh it. Have not restored any backups from titanium or anything but still not working. My next idea is to run a CM backup but need everybody opinion first. Would like to stay on this ROM is possible.
Did she perhaps download an app, and then this happened?
Did she maybe delete ringtones? or mute them?
When you said they changed, you mean, a different ring tone than what she set it at?
You say you wiped and refreshed phone...I assume you wiped cache/dalvik cache in recovery then rebooted. Which is fine but if that didn't do it......
When you pull up the different ringtones to set a ringtone, are there any listed?
Not sure if from new app or not and no haven't partioned card. Apparently relishing did fix it after all. I don't know what caused it but it's working. Thanks guys. I busted screen on my evo so I'm sorta screwed myself. I can see about an inch and a half bottom right. I've got orientation on for all sides, trying to get the most out of that small window.
