Root help. phone wont root.
Its in debugging mode. i downloaded the drivers but it doesnt seem to install or somethings missing. i when i click on the run.bat a black window pop opens and nothing starts..
Do you have the lg ms910 drivers installed ? You made sure you have zvb version on your phone. If it is zvc then you will have to downgrade to zvb following gbi's instruction .
If you have an Anti-virus program make sure to disable it.. Then extract the winrar file again and run it... I had the same problem until i disabled my Anti-virus and it worked.. Hope it works..
