Root HELP! Phone wont turn on
If you can get into dl mode then use odin and flash to stock b4 returning phone to sprint to avoid any possible warranty issues. Besides, since phone is going back there will never be a better time to learn and not to worry if something gets borked. Odin is your friend, you just need to get to know it:-)
I just reread this thread and looked at your pic again. To me it looks like something got borked when trying to flash. Pull battery for 10 seconds, put it back in and get back into dl mode - physical keyboard open>press and hold the #1 key and press and hold the power key in that order until the big yellow triangle appears. Connect usb and then run odin again.
