CaseyKees
I just got the new Rezound, and gave my Incredible to my husband. I did a factory reset and cleared the SD card before I transferred it to his phone #. He said on Monday he received an update and ever since then he has not been able to access the internet.
When you power off and turn back on, he gets a pop up that says.
"UID on the system are inconsistant, you need to wipe your data partition or your device will be unstable."
Then there is a button that says "I'm feeling lucky".
Is this some kind of a virus? Do I need to do another factory reset? I hope someone can help!! It was working fine up until I gave it to him and did the factory reset.
Thanks!
Thanks!
