Root Help please! Unroot trouble, Stuck at HTC Logo Screen!
XnRenteria
Okay, i am a complete noob to to rooting and all that has to do with rooting android phones, so please bear with me. I recently purchased a HTC Amaze 4G from my friend and he told me it was rooted. I messed with the phone for a few minutes and realized that i have no idea how to use this root stuff and no longer want it on my phone. I did my research and i learned how to unroot the phone. The guy on the tutorial said all you have to do is delete the su files off of the bin. folder and i did that but it didnt work. :mad: So then I decided to do a hard reset from HBoot. So i did the hard factory reset, but once i tried to reboot my phone the worst happend. NOW I HAVE THE HTC STUCK LOGO PROBLEM! Now every time i reboot it gets stuck on the HTC logo. So researching a little more so i can learn to fix my new problem, i came to a forum post that taught me how to install the stock firmware on my HTC Amaze. (This is my first post on this forum so i cant post any links) I really dont know what to do next. Please Help. Sorry for the long post, i wanted to be as descriptive as possible.
Well first step to this is... Are you able to boot into hboot ?
Hey man, i solved the problem thanks to you! You helped someone else with a similar problem and I used your info to fix the problem! thanks man! You saved my phone!
Glad you solved it dude. Yeah usually there are similar threads here cause this seems to be an issue with this phone. Glad I switched to this bad boy (tmo galaxy s4)
I figured people had similar problems. Luckily I found a solution. Nice! Good luck with the s4 and hope you don't run into any problems. thanks again for the help.
