HELP please with micro sd samsung galaxy s3
MoY
Hi.
How do I program my phone to automatically save images from the net or music onto my new. 16GB micro sd card.?
I've formatted the sd card properly but things keep saving onto samsung galaxy s3.
There's an icon labeled "my files" and not sure which one is the micro sd. There is the ex sd card & an sd card.
Thanks advance.
Mi Moy!! Welcome to the forums!!:D
Check your browser settings.
Should be in there, where to save
downloads.;)
Welcome to the forums.
Usually when the device isn't rooted everything defaults to the internal storage of the device instead of the SD card. And unfortunately again you would need to root to move everything over like apps and such.
Music should be able to be moved Werth a file manager but I believe the downloads folder defaults in internal storage.
Hope this helps :)
downloads.;)
I feel embarrassed, it worked though thanks!
Also, If I may add, if my downloaded images that were saved to my phone got deleted ( IDK How BTW) I suppose there is an app to bring them back?
Thanks in advance.
downloads.;)
Thanks.
Right now I don't have any music saved, so I listen to Pandora for the moment.
I checked the browser settings and i'm afraid there aren't any settings for what I need : /
