Root help please
david111
i have a rooted vibrant running on 2.1-update 1. i have been trying to update to bionix fusion12 rom. and after i get through rom manager and click on the fusion12.zip file it reset into system recovery and i get a error.
E:cant open /cache/update.zip
(bad)
installation aborted
please help
Personally I dont like using rom manager to flash it seems to be causing problems with alot of people. I only use rom manager to get clockwork.
Your best bet would be to download a app on the market called astro. Its a file manager. Download the rom directly from the site then go into astro find your downloads and rename the Rom file to update.zip and move it to the root of your sd card. Then boot into recovery and apply update.zip and that should work. If not there are other options like flashing through odin.
