Help please
iRENEE
Well, I dont know if this thread should be in this section, But I'm desperate .
While I was on my droid hearing music in the car the screen froze. So I just took out the batteries and then waited a couple minutes and then put the batteries back in, then it wouldnt let me unlock the screen. (slide to unlock) So I'm sliding my fingers to unlock it it wont sense it. It wont let me unlock. And then the light on the top right hand corner is blinking red, but the battery life on the phone says its half way full. So thinking it was frozen again I took out the batteries and put it back in, it still wouldnt let me unlock and then the SD (ithink) icon popped up with an error sign..
Help? :\
Help? :\
Welcome to the forum,
A few quick questions,
1. Are you rooted? (I'm guessing no but don't want to assume)
If you are rooted what ROM are you running?
2. Do you know how to get into the recovery mode?
3. It may be that you sd card went bad or has problem. One thing to try is remove the sd card and reseat it. If that does not work take it out back it up to your computer and then reformat it then copy your files back.
This is something to try and start with. Also ask anything your not sure of.
