Help Help please?
jungtaee
Hi I have HTC incredible2 My market, gtalk, and gmail doesn't work... For the market its stuck on loading screen and then it closes Gtalk has an error Gmail has a same error as market.
Help?
Thanks
Also, I had this problem before and went to a Verizon to fix it . They fixed it for me by doing factory reset but i have this prob agen...
Greetings jungtaee,
If verizon fixed your issues with a factory reset, i'm wondering if you installed some app that is either conflicting with or is disabling your data.
Pull down your notification bar, select the settings tab and make sure your data is selected.
If this doesn't have anything to do with it, make sure the last few apps you installed aren't causing this issue.
If worse comes to worse, I suggest another factory reset. I'm not sure how much time passed between when verizon reset your phone, and when your problem returned, but I would wait a little bit before putting any apps back on your phone to see if the problem returns. This way you can weed out if its your phone or apps that is the actual problem.
Hope this helps
Yes.
From the home screen, tap the Menu button. Tap Settings. Tap SD & Phone storage. Scroll down to Factory data reset and tap it - follow the prompts.
Please understand anything not stored on your SD card (data, apps, etc.) will be lost. On restarting, the phone will require you set up your Google account again. Once set up, the phone will try to recover the apps it knows about but sometimes an app may be missed.
