Root help please
iamloco724
dont know if this is normal so i dont know what to do..i was up to downloading the sholes rom right at 99 percent my screen timed out i went to put the screen back on and now it just stays black..wat should i do from here?
tried just rebooting?
tried battery pull?
reboot into recovery?
factory wipe?
Those are the 4 things I would try in that order
i pulled battery its having me download the rom again..what should happen after the rom is downloading in sholesmod?
k right now i have it so the screen doesnt time out for 30 min to prevent nay possible problem again hopefully smooth from here on
im at the first select package to install screen and dont know what to select to get this 2. Install 2.0.1 launcher w/ 5 screens
