Help Help please :)
natee
Hello~
My phone was in the process of being rooted and it got removed from my computer. After I tried to restart it this is what came up.
android system recovery <3e>
Enter: OK Key, Select : Vol UP / Vol Down
*reboot system now
*apply update from sdcard
*wipe data/factory reset
*wipe cache partition
-- Copying media files...
Successfully copied meida files.
I could use the volume buttons to scroll, but it would not let me push ok. So I got myself a USB jig, and got it into download mode, now my problem is it seems odin isn't reading my phone. D: Is there anything I can do to fix this? QQ
On this phone the home button is the ok button. Did you try that?
What method were you using to root? Did Odin recognize your phone before this happened?
