I am wondering if anyone can help me disable my text preview on my lock bar. I tried going into my privacy settings and I don't have any lock bar settings in there. Also, I've tried the apps and I don't like them. Help please?
Okay. So you're running the stock ROM with Sense 2.x. When you go to Menu>Settings>Privacy what options are available? Mine shows 3 different options: Display message on lock screen, Back up my settings, and Automatic restore. If I have "Display message on lock screen" checked, when I get a text message, it will show on the lock screen. If I uncheck it, the message does not show on the lockscreen.
It would be very unusual if your settings didn't have this option. Also you're calling it a lock bar. Are you running an app like WidgetLocker that changes your lockscreen from the stock Sense lockscreen to something else? If so, perhaps there is a setting in the app that controls whether the text is being displayed.
