Help HELP!!!!!! (please)
Hi (i'm a complete techno fail so bare with me:eek:)
I completed the new update on my Desre S on saturday via wifi, when i turned the wifi off and left the building i was in i lost all network capability other than messages and phone calls, but they were taking hours. I was left with no internet etc. I have taken the battery out, turhned off the network then on again taken the sim out etc... nothing works, i now have no signal at all!! naada, nothing, zilch!!
I have had similar problems to others with slow messages and reboots for no reason etc... but this has baffled me :confused::confused::confused:
any help would be appreciated!!
AC xx
Hello and welcome aboard. You might get a faster response for this issue over at the Desire S sub-forums.I'll move your post over to that forum. :)
Here is what might possible fix this problem. Sometimes after updating a device, there might be some 'glitches' involved. Just to make sure the update was updated successfully (without any issues), doing a full reset usually fixes this kind of problem.
Follow these steps: From your home-screen > touch the menu key > settings > sd & phone storage -- scroll down to Factory Data Reset. keep in mind that this method will erase all data.
I hope this works for you.
