Root help please!!
ok my pc know recognized my phone and i did what you told me too do and i got my phobe tampered relocked but i still get not luck with RUU finished this what it say
Error {158}: image error
the rom update utility cannot update your android phone. please get the correct rom update utility and try again
do you know what i need to do what im doing wrong?
aand thank you for helping me
Make sure the RUU is for K2_CL. Do not use K2_UL, K2_U, or K2_PLC_CL.
ok same error and now phone turn on and when i turn it off it turn on again with a new message ****security warning****
Boot into fastboot mode then relock your bootloader
fastboot oem lock
Then run the RUU while in fastboot mode....
Make sure you have your Unlock_code.bin from HTC handy to unlock your bootloader again after it's done if you wanna flash custom recovery and root again
i got he unlock code bin but before i root it again i want to fixed then read alot and learn then do it at this time i already download that ruu file from 4 places and still get same error
do i put it on sd and then install it via recovery zip update then run RUU?
Put it in the same folder that has your fastboot files. Boot in to your fastboot. Then type and enter in the command window:
fastboot oem rebootRUU
Then, go ahead an type and enter:
fastboot flash zip nameofzip.zip
ok ty then i can run RUU?
That zip file is the RUU. I pulled it from the .exe file. Its encrypted which allows someone to flash the zip when or if they have problems with the .exe file and also it allows those who are S-On to restore their device more easily.
no luck guys i did step by step
first i download and put on same folder the rom.zip in fastboot folder
then open command promt and typed fastboot oem rebootRUU and then fastboot flash zip rom.zip and i get the follow message
sending "zip" <616945 kb>
failed <remote: unknown command>
finished. total time 0.000s
rom.zip from RUU_K2_CL_JB_45_S_Sprint_WWE_Boost_2.06.653.6_Radi o_1.12.50.0516_10.30.42.25_NV_NV_Boost_2.20_150
Code:
rom.zip Md5Sum: 1f322c8bda13e4949721d353a92ed3b7
