Help help pleassseeeeee
so i'm completly non technical and really desperate for help
is there any simple way of transferring files over from my galaxy s2 to my laptop without using wifi.
i have no wifi to use and the usb wire will not work
can anyone please help
Applications utilizing networking are more sensitive to network glitches/failures. Try to restart the application.
For the USB to work have you tried restarting your phone- aka turning it off and than on and seeing whether it will connect using usb?
Also go into your windows update and make sure that windows media player is successfully updated - the services that are packed into windows media player are responsible for recognizing and installing drivers for your phone.
In more complicated words the Environment for MTP and PTP devices are packed with the stupid Microsoft Windows Media Player and if that is either not present or not updated on your computer you will not see MTP or PTP device being mounted or even recognized by your computer.
Hopefully this works!!!
