Help pleeez!!
mrbigv770
I'm trying to install Woodstock's B08 nandroid with CWM.
CWM can't find it. I already cleared my cache and data.
He kept saying to put the nandroid on the clockworkmod/backup folder...but I didn't see it on my sd card. So I just put it on the root of my sd card.
What do I do now???
Wrong folder indeed. If you don't see the folder, you need to create it, first a clockworkmod folder, then a backup folder, as you described.
