Root [help] Problems with 4ext and TWRP -SOLVED
skarni
I'm trying to get 4ext back now that I solved the boot loop.
In bootloader it tells me:
UNLOCKED
S-on
Hboot 1.57.0000
eMMC-boot
HBOOT
CID incorrect!
Update fail
press <power> to reboot
I can boot into android (JMZ stock)
I have installed 4EXT and it tells me busybox cant be found. I installed busybox and it tells me "there is a problem opening a shell with root access caused by superuser/supersu. Superuser is empty, super su tells me no SU binary installed and superSU can not install it.
I need some help, please.
tried to install TWRP 2.2 and that didn't work either.
just had a power outage as well so no internet!
Yes I did flash the PG86IMG.zip files. That is what got me into trouble, because it was the TWRP 1.1.1
Remove your SDcard and connect it to your computer. Delete the PG86IMG.zip in your SD card.
Put the card back in and you should be able to select recovery in hboot.
Okay. I got 4EXT back. after installing JMZs stock Rom it was not rooted according to root checker. I installed Harmonia and from there I was able to launch 4ext.
Now I'll try Mobster 2.25
Thanks again for a great helpful community!!!
