M
ModdingMyMind
Guest
I just read your last posts. You said you accepted the 4.2.2 OTA? So you are currently on 4.2.2? The deodex Rom is based on 4.2.2 however, CWM will not work with 4.2.2 except on ONE CONDITION. You must downgrade your HBoot from 2.21 to 2.00. Otherwise, you cannot use CWM anymore and will be obligated to use TWRP which has been built for 4.2.2 and is now also officially supported by TeamWin after I contacted Dees_Troy over on XDA.
All versions from 2.7.1.1 and up over on the TWRP website referencing the K2_CL device is compatible for 4.2.2 only. Use that recovery and your problem will be resolved. Make sure you make a backup when you get the chance ;-)
