Bl4z3
I'm going to install some 2.2 roms so I installed PB31IMG.zip via holding power +vol down and that went fine. So then I did
to install the radio update and it's stuck on a black screen with a red triangle and exclamation point, what do I do? I held the power button and nothing happens, if I try to run and adb command it says device not found. Please help!
Thanks
Code:
adb reboot recovery
Thanks
Now I can install one of your roms
