Root HELP. radio flash
tazman904
so Im rooted. S-off.
last night I installed skyraider 2.5.2 after that i installed radio 2.15.
I was told i need an OTA file then re root.
2. things. I dont understand why I need the OTA file. and why cant i just load a different radio. like 2.05
while i was trying load the OTA file, im getting an error message. it wont load. its not double zipped. Ie: zip.zip any suggestions.
I dont want a brick.
i am pretty sure you just need the 2.15 radio file, then rename it to PB31IMG, and use hboot to get the radio.
Who told you you needed a different radio, if your on 2.15 and not having issues leave it be would be suggestion!
