P Possum15 Lurker Apr 14, 2010 #1 Downloaded a mod to my SD card and installed using Astro. Removed from my SD Card but it's still on my Hero. Anyone know how to get it off? Thanks
Jaffa Android Expert Apr 14, 2010 #2 Are you running a custom ROM, are you saying itwas installed to your SD card? if so I dont know, if not removing the installer from your Sd card wont get rid of it, get Quick uninstaller from the market and remove it that way..
