Root Help Removing Yellow Triangle At Boot
Cuzuaintme
The current threads we have on getting rid of the triangle are not fool proof. I would be grateful if someone can provide steps that are newb friendly. And besides, there might even be a simpler method than the ones already posted. Can't really risk bricking when the instructions are not too clear.
Will be greatly appreciated!
From all thats written on the XDA site this will only work for those systems running true ICS OS. And even then its dangerous if you make a mistep and could very well brick your phone and not a soft brick either.
Anyone willing to delve in and try and find a workaround had better be very good as a dev. All I'm doing is repeating the warnings from their site.
While the triangle can only be a problem if you must bring your phone into corporate for servicing or replacement other wise its just something to bug the hell out of you everytime you boot up. Not to mention its pretty ugly.
i can repack the kernel that your using to get rid of the rooted rle picture. just let me know which kernel you want and i'll upload it. all you have to do is change one of the .rle files and repack the boot.img.
it will remove the triangle on boot, if you want to switch your phone, um.. idk.
Remove all root apps and take the sdcard for sure though
