Root help reply quick!!!?
adventage
I think I rooted my phone, I have a customy recovery on it (attached in post) my bootloader is unlocked. I have everything installed. and apps with superuser permissions work and everything. so I am rooted.
but do I have to have s-off to install a custom rom?
and if I need s-off can someone give me a link to achieve it on android 2.3.5 thats easy and simple
no you do not need to have s-off to flash a rom. as long as you have a recovery and your bootloader is unlocked, then you are good to go. there are ways to get s-off if you want, but they are more complicated and there is no real need to do it. but i will leave that up to you. here is the guide you will need:
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
thanks, and can you help me with one last thing?
I'm looking for a really good stable sense 3.0 rom and how to put the rom on
for just a pure sense 3.0 rom then i recommend mik3d. i have an evo 3d now and it is identical to the stock sense 3.0 rom that me 3vo has now. pretty cool.
http://themikmik.com/showthread.php?9555-Mik3D-RC1-10-31-2011
and for directions on how to flash a rom go here:
http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html
heeeeeeeelp I flashed and everything and I have the rom but everything keeps force closing
sounds like you did not wipe everything. did you follow the guide as to how to flash a rom? what did you wipe? wipe everything except sd card and re-flash it. also did you make a nandroid backup prior to flahsing the rom?
yes I made a back up, and I'm back to stock.
and I followed the guide but I am not sure at what to wipe. I wiped
"cache partition" "dalvik cache" "wipe data" and I fixed permissions. then I rebooted. rom started. and I couldn't do anything with out force closes popping up. what is your advice?
so here are the basic steps:
1.make a nandroid backup
2.wipe at least data, cache and dalvik cache (you can wipe everything but the sd card, if you like)
3.flash the rom
4.reboot
sounds like you flashed the rom and then wipe. this will not work. you need a clean environment for the rom to be installed.
3.flash the rom
4.reboot
now it booted htc evo 4g screen then took me back to recovery
edit: its working so far. now when it loads I will test.
edit edit: its works THANK YOU so much for your help!!
