CoolioShmoolio
My triumph does not connect via usb cord, either into the computer or travel adapter, so I am about to send it back for a replacement since it's still under warranty.
My problem is that I had rooted the phone in the past with GingerBreak and was wondering if it was sufficient enough, (in terms of not voiding the warranty), to just un-root it and perform a factory reset. I also still have the stock recovery on there. I've read: http://androidforums.com/triumph-al...de-100-stock-motorola-triumph-newb-proof.html
and noticed that you are supposed to restore a nandroid backup of the stock mod, however I'm unable to restore any nandroid since I cannot hook up to my comp and put CWM on the phone.
If anyone can help me with this dilemma, it would be greatly appreciated. Thanks
roud:
