shaggylouie
I downloaded root explorer twice and it still will not open. It's stuck on SU Request. Is this normal? Any quick advice would be greatly appreciated. Thanks!
Can I use root explorer to find if my apps are on my sd? if so, how?
You should be able to. In XTR Rom, first do Settings->SD card & phone storage. If you see "Internal phone storage", available space of over, say, 90 to 100 MB (mine is 137 right now), you probably have a2sd.
In Root Explorer, go to the System folder, then the Sd folder in there (or, /system/sd), and you should see folders for app, app-private, dalvik-cache. If so, and there are apps in there, you have a2sd.
Did this (thanks!). I do have a2sd. BUT, how do I transfer apps from one ROM to another. It worked once for me automatically (not sure how) and now I can't seem to have it work again.
