You are using this to root right?
http://androidforums.com/optimus-m-...-kit-optimus-m-2-2-2-dummy-proof-3-click.html
Yes. It doesn't work.
ok guys, I tried everything, enable debugging, disabling sotarage, format my microsd, i tried in two three different computers, and nothing. Usb drivers work fine. This patch doesn't root my phone, but instead it creates a root folder in microsd with files that i cannot open because something is missing, the only file that i can open is superuser older version.
I am totally sure that this bat patch was not made for Optimus M (says S in the description) and it can wipe all your phone if you try to go the recovery. (already some users reported it). So it works for only some OM versions. Several have my same problem.
I think this patch is unsafe for people who doesn't know what they are doing, so be careful with it. I don't recommend you to use it.
Here is my log:
Waiting for device to be connected [press CTRL-C to cancel]... Found device
Proceeding with install
---- BEGIN LOG ----
...Proceeding to copy necessary files...
push: copy2tmp/install-zerg.sh -> /data/local/tmp/install-zerg.sh
push: copy2tmp/install-zerg-auto.sh -> /data/local/tmp/install-zerg-auto.sh
2 files pushed. 0 files skipped.
20 KB/s (906 bytes in 0.044s)
push: copy2sd/000root/xionia_cwma_12518.6.img -> /sdcard/000root/xionia_cwma_125
18.6.img
push: copy2sd/000root/Superuser.apk -> /sdcard/000root/Superuser.apk
push: copy2sd/000root/su -> /sdcard/000root/su
push: copy2sd/000root/recovery_vd.img -> /sdcard/000root/recovery_vd.img
push: copy2sd/000root/install-xionia.sh -> /sdcard/000root/install-xionia.sh
push: copy2sd/000root/install-vd.sh -> /sdcard/000root/install-vd.sh
push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh
push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh
push: copy2sd/000root/install-cleanup.sh -> /sdcard/000root/install-cleanup.sh
push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image
push: copy2sd/000root/busybox -> /sdcard/000root/busybox
11 files pushed. 0 files skipped.
2997 KB/s (12815963 bytes in 4.175s)
...Running Zerg exploit...
Unable to chmod zergrush: No such file or directory
/data/local/tmp/install-zerg-auto.sh: ./zergrush: not found
---- STATUS of ZERG on PREVIOUS few lines ----
/data/local/tmp/sh: not found
---- END LOG ----
Check the STATUS of ZERG above, this exploit depends on a
condition which doesn't always hit
If you see
[-] Zerglings did not leave interesting stuff
Then the exploit did NOT work during this pass
After reboot you'll need to RE-RUN the root install script
It may take SEVERAL attempts before the condition hits
If you see
[+] Rush did it ! It's a GG, man !
Then the exploit was SUCCESSFUL. Script will reboot, then you are DONE!
Keep in mind, should you CHOOSE to run "su", you will be prompted
for permission on the phone's screen during the first run. If you
do not ALLOW this prompt you will get a "permission denied" error
turn ON phone
make sure you have EXITED the lock screen
run "su" from "adb shell"
accept the prompt on the phone's screen asking for root permissions
It is NOT required to run "su". You ARE ROOTED regardless.
Getting ready to reboot...
Press any key to continue . . .
You can tell that the Zerg exploit didn't work out: "/data/local/tmp/sh: not found"
