Ok do you have instructions in how to do so. Also which Rom is the best?will it hurt my battery life. And what are some pros and cons to rooting. Thank you.yes, yes, and yes!
listen buddy i'm not going to hold your hand through the process... if you don't know the pros and cons of rooting then perhaps you shouldn't be doing it. try doing a search, or simply just browse through this forum and all those questions have been answered several, if not hundreds, of times.
good frickin luck
I'd say u probably don't want to update to froyo yet. It's got a buncha features missing right now so i'd say wait untill its a little bit better
Google is your friend and so is the search feature. If you don't want to hold his hand let the thread die. Like I'm going to do riiiiiiiiiight now.
I'll give you some credit. At least you have pointed questions, but still basic. I just hate seeing this in root/jailbreak threads. It's a semi-advanced topic that shouldn't be done with hand holding.
Chill out guys, we were all in his position at one point. He just needs a point in the right direction. To the op, check out xda. They have great walkthroughs that will help out. To start check this link out. Great walkthrough step by step. It's toast's rooting method. Doing this will give you a general idea of adb commands and processes of android.
Simple Guide for Rooting (Tweaks Coming Soon) - xda-developers
