Root Help!! Rooted Evo won't boost past error screen
sonicfury
Whenever I try to boot my phone, I see the white splash screen, and then a black screen a shows few seconds later with an error symbol that looks like a triangle with an exclamation point in the middle of it.
Here's what got me here:
1) Rooted with Unrevoked3
2) Flashed CM7 ROM
3) Unrooted phone using unrevoked3 (S-ON), and then flashing a PC36 image.
4) In the process of re-rooting, tried to enter recovery from HBOOT while plugged into USB.
I don't know what to do... I'm bricked!!! Please help. Thank you,
Dusty
Ok, maybe it was a false alarm, my apologies. I went into Fastboot and then hit Reboot. I'm going to try re-rooting again, hope this works... I had a bit of a scare!
Quick question...why did you root, flash a ROM, and then attempt to unroot your phone?!?
I needed to take my phone in for repair for some screen problems. I unrooted just in case. They just ended up replacing the screen and giving the phone back to me, so then I needed to re-root. Sorry again for the false alarm guys
