MongooseGA
Member
Hey all,
My Evo is rooted, running the new Mikfroyo 4.5 and a Netarchy 4.3.1 cfs-havs-nosbc-universal kernel.
I just purchased and downloaded SetCPU from the market, and while playing with the settings, the screen froze while running the app. Powering off with the power button did nothing, so I pulled the battery and powered back up.
The phone is stuck on the initial "HTC EVO 4G" splash screen. I pulled the battery again and tried to reboot into recovery. Still no dice.
So The screen has been stuck for about 10 minutes as of my last attempt and it's getting sort of irritating. Any advice?
Thanks in advance,
G.A.
Thanks in advance,
G.A.
. Here's the thing with setcpu - if you set the max to high, your phone won't be able to handle it. I suggest going no higher than 1152, but some can get away with 1190. When testing the max, *never* leave "set at boot" checked, or you'll be in trouble. In any case, just remember to be careful.
