help, rooted samsung stellar
Ok my touch screen and soft (home, menu buttons) will not work or resound at all!!!! I took out battery a 1000 times. I have no idea other then my ROOTED phone is fried.... help asap please
do you have recovery? if so try and wipe dalvik cache and cache and see if that helps.
if not have you flashed any roms. i know from your other thread that we provided you a link with a custom rom. did you flash that?
if none of those suggestions work then my friend i think it will be safe to say that you have a hardware issue. hardware issues i would take it in to have it fixed or replaced.
not sure what else you can do.
Really tho, put of no where my stellar turnt off then back on and now the soft keys and touchscreen will not work I've restarted 3 at lest times using the power up. And then I took battery out a lot lost count. I'm in a situation ... I am rooted. Please help.
ok i merged your two threads together.
like i said if you have recovery and tried wiping and or flashing a rom and that has not worked then it sounds more of a hardware issue.
