Try going into recovery mode and clear storage and then try unrevoked again.
You aren't using unrEVOked forever are you??
Are you using the latest version of unrEVOked?
"Dalvik cache is a program cache area for the program dalvik. Dalvik is a java based virtual machine that is the bases for running your programs (the ones that have the .apk extension). In order to make access times faster (because there's not JIT (just in time) compiler installed by default), the dalvik-cache is the result of dalvik doing a optimization of the running program. Sounds confusing. It's similar to the prefetch files in Windows."What will clear storage do? Will it erase the things on my phone, (apps, pics contacts ext...)???
Sorry, meant Dalvik cache, thought my last post explained that.Clear storage wipes the sd card doesn't it?
Thanks!Yeah but just wanted to clarify![]()
Recovery, advanced, wipe dalvik cache, confirm.Okay, then two questions. How do I do that? Clear the dalvik cache, and backup my sd content to my computer.
Thanks LECTOR, but I have and issue. When I select boot recovery, it shows me phone with a warning sign. How would i go around solving this issue?
Thanks again.
Wait a minute, you're on a CDMA phone (non SIM)?Me too.
I am yes.
Yes, I am as well.
Thanks again.
The only way I know how to wipe Davlik cache is through recovery.Thanks SUroot for the clarification. Is there another way to clear the davik cache? And LECTER, I'm using OS X, but I have access to both Windows, and various Linux distros if it would make things easier.
HTC Sync is gone from both your computers?
