Root help rooting this old a** evo 4g phone
zacharynasty
i need some help rooting this evo 4g, i tried everything, its so confusing unlike any other phone ive ever had to root, any help would be appreciated..
Can you post back here what is listed in your bootloader screen?
Is it up to date as far as software?
You can also check this out:
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
Just let us know what you need help with :)
Edit: sorry, I see you had another couple posts in that guide:)
Are you having an issue with the HTC dev method?
i have the 2.3.5 and the newest 5.07.651 software, and i have the hboot 2.18..
i tired this method along with a few others
public:windows_hboot_driver_install [RootWiki]
and this method, but i just cant get it to work...
Gingerbread(2.3.5) Root Guides
http://androidforums.com/evo-4g-all-things-root/488901-rooting-gingerbread-2-3-5-dummies-guide.html
[GUIDE][WIP] How to achieve S-OFF after unlocking 2.18 HBOOT with HTCDev.com - No More Watermark!
ive also tried the htc dev method too, and i got to the driver installation part went thru it but it just doesent work...
yes like i said in the guide thread, all of the methods work. in order for us to help you we need to know exactly where the issue is. the more detail you can give us will help us better to help you.
so like biker57 has asked, let us know what step you are on thatis giving you the trouble and also what error you are getting.
and lets keep the conversation here rather then the guide thread, since you have started this one. no need to have two conversations on the same topic.
When you tried the HTC Dev mentioned can you tell us just were you had your issues during steps 1 thru 15.
when i go into fastboot plug my phone in, and when it says all the files u need adb.exe adbwinapi.dll fastboot.exe, then it says to put them in a folder /android, i do all of that. then it says to find the files it says run the sdk manager, then wait and it will update, i have sdk manager but when it starts and i wait for it to update, then i install android sdk platform tools and android sdk tools.....and it says please update if ur sdk version is r11, but when i open all of that i dont see everything i need to check off, on the screen shot of it on the htc dev site, it shows api13 in one of the shots, and when i go to the same screen i dont see it, its under android version like 3.1, i dident think something was right so i dident continue...but i did the command prompts but i couldent get it to work then the c:/android prompt worked, but the fastboot oem get_identifier_token would not take, and i tried typing it in everyway caps and all, but it wouldent work, finally it did, so when i got to the part where u need to copy and paste the device token it would not paste, and thats as far as i got, so i gave up, i have all the drivers i ever factory reset everything it said to do, i gotta be missing something...
also i dont know where to get sdk manager i have the file sdk-tools but not the manager
We're sorry, but it appears your attempt to unlock the bootloader on this device has failed. This could be caused by several factors including simple errors in the entry of the unlock token, problems with your device, or a lack of manufacturer support for the unlocking process. Please see the specific error code listed below, and try again if necessary.
Error Code: Invalid Bootloader Token Length.
Error Reason: The submitted Token appears to be the wrong length and won't work.
so after i re did everything this is what it told me..
ok sounds like you are not copying and pasting the code correctly.
it needs to start and end here:
<<<<<Identifier Token Start>>>>>
and end with:
<<<<<Identifier Token End>>>>>
it worked i re did the token, and i guess it was the way i copied it, i was off by half a milimeter haha technology, it said it sent me an email with a unlock key
ok so i unlocked the bootloader finally, now what do i need to do
nevermind i forgot about unrevoked, its running now
i got cyanogenmod 7.2.0 supersonic, 2.3.7, unlocked bootloader, but my s-on is green, idk how to get it off, i tried the unrevoked forever method but it wouldent flash, i have amon_RA recovery
What do I use if its not necessary, do I really need it to say s-off, I seem to be added different roms and stuff, like it doesn't seem to be stopping me from doin anything
correct. the only reason why you would need to have s-off now is if you want to use PC36IMG files. these are files that are used to change recoveries, boot animations or splash screens, or updating your radios.
flashing roms and such are fine with s-on.....so it is up to you if you want s-off or not. it really is not all that hard to do.....your call;)
I tried getting it off with the captain method, but I couldn't get it to work
well, if you want to go that route, we need more specifics. what happened? where are you having the issue? at what step? was there an error?
the more info the better.
It just wouldent flash, I think it said file not found idk, Its not a big deal tht was awhile ago I dnt remember exactly, I'm not wprried about it now, I just flashed miui 4.1.2 looks cool
