Root help rooting zte awe
Hi there!
I've moved your thread to a more appropriate forum where others with the same phone can better assist you. :)
The poot method didn't work for me but the impactor route worked first time, although my awe updated and I lost root. Just ran impactor again and currently have root access. Now if I could only get wifi tether to work! I've tried a few apps to no avail
Ok, so Ive tried looking around but just cannot figure out how to root with Cydia Impactor.. ive tried installing SuperSU but it says no root binary found.. thoughts?
In the settings of your phone make sure that usb debugging is on. Connect your phone and install drivers if you haven't already. Then on your phone select connect to pc software. On impactor press start. Wait for it to finish, disconnect your phone then try to install SuperSU again.
Ok I finally rooted my ZTE AWE. I tried Motochopper and Cydia Impactor . I got it rooted with impactor but I think the only reason Motochopper didn't work was because i didn't unplug and reconnect my phone in software mode after installing the drivers. Impactor was very easy to use. Can't wait for Clockwork Mod and some new ROM's. Please post if anyone finds any for this phone. :D
