I downloaded launcher pro, now I lost my Google voice search bar off my screen. I use that almost everyday, is there a way to install it again and still keep Launcher pro.
you can hold the menu button down and it will take you do google now, which is the same thing. but i dont recommend using launcher pro anymore, it hasnt been updated in about 2 years, the newer ones are much faster
Hey so i recieved my S4 today and i realized that the button to lower the volume seems to be more pushed in then the button to make the volume higher, may i know if this this normal? thanks
