I'm having similar issues. My G1 sees the card fine. When I plug the phone into my PC, it recognizes it and assignes a drive letter, but it won't let me view the card. Pmompts to "insert disk". I've even unmounted from the phone, the plugged it in, still no dice.
Thoughts?
When you format it, make sure you use FAT32, as FAT is only an 8bit file system.
ok so i have a kingston 1gb micro sd
the sd card taht came with the phone was defected.
now when i connect my phone to my computer(mac) it doesnt come up at all. but if use it as usb storage its fine...
anyone help?
Couple of things... Do Sd card swaps only with power completely off. Make sure the the little cover is closed completely ... or the phone will not recognize that there is a SD card present ... Next go to your settings and under SD Card & phone settings unmount/eject card then power down, remove card and close cover, reboot phone, after phone is rebooted you should have no errors. Insert MicroSD card and close cover ... reboot and go into Settings ... select SDCard & phone Settings the Total space and available should show on screen now ... if it doesnt try pushing the SDCard cover to make sure it is seated securely once that is in place it should appear.
I have had 1GB, 8GB, & currently and using a 16GB in the phone without issues. Good Luck !
