justjimjpc
Premium Member
it will sort out your problem
Not sure what you point is ? Are you asking a Question ?
If your SD card is not being recognized ... then another thing is to see if a card reader will read it ... if it does then try the following !
1.) copy all the contents of the SD into a folder on your PC.
2.) then format the SD using Fat32 formatting
3.) copy all the items back onto the SD
4.) re-install the SD in your phone ...
5 .) Now all files should show on your SD when viewed with a file viewer or if you Mount the SD with your data cable hooked between the phone and your computer..
If it doesn't then you may have a phone sdcard socket problem ...
