Help help sending picture texts
reedj24
I have been having a ton of trouble getting my phone to send picture texts.
It doesn't seem to matter if I'm of 4G, 3G or Wifi. Doesn't seem to make a difference if I'm sending to one or multiple recipients or use the stock messenger or handcent.
I've searched to see if I could find a solution but have been unable to locate one, so I'm asking you fine folks for some help.
Any thoughts? Your tips and suggestions would be greatly appreciated!
Happy New Year!
Not sure about Handcent, but check the settings to see if there's anything about file size limits? I know some phones it does depend on the size of the files for some networks / recipients. Try sending a smaller file, see if that helps to narrow down what might be causing it.
