Help Help starting my phone
I don't know what the hell happened. I turned off my phone to restart it and when I did it didn't start up. The phone stays on the bootanimation. The ****ing droid justs keeps pissing on the apple over, over, over and over again. Anyone ever had a similar problem before that got resolved/fixed?
Did you remove anything important or modify any system settings using root tools before you shut down your phone?
I really can't be sure. If I could access my phone I probably can figure out the problem. I can get another LG Optimus M for $10 from metro but that would take three days, I can't be without a phone for that long. I really don't know what happened...
Edit- I take it that I bricked my phone. I already went to a metro store and talked to a clerk, like I said.. a three day wait till a new phone. Shit sucks. At least I now know what not to do, lol.
I agree. Getting stuck in a boot loop is pretty common on this forum and fixed relatively quickly. I've had it happen to me more times than I care to remember. Most of the times it's b/c I uninstalled/installed/froze something I shouldn't have and a simple nandroid restore fixes it right up. If that still doesn't work, then full restore via lgnpst is the way to go. Good luck
Another way you might have screwed yourself is you have a great chance of getting this new ten dollar Optimus and having it be 2.2 I say follow the unbrick guide if you still have the "broke" one
