Yeah tried battery pull and holding down red button reboots, poking around the webbernets and finding out I could fix it with a recovery thingy like joey's which I don't have so I may just do a factory reset from recovery.
if your gonna have to do that ANYWAY use the SAME updater and put joey or forcytos on it. might as well root if you have to do THE SAME STEPS to reflash anyway
