Help Help! Stuck in boot loop
BoMonster
So I applied a battery percentage mod without doing a nandroid. Now I'm stuck in a boot loop. I tried reapplying the stock battery in recovery and still looping.
Any ideas? Please help...I'm sweating here.
Thanks
Bo
UPDATE: I decided to try to redo the RUU update and start from scratch...it worked, whew. Lesson learned. Backup is there for a reason.
Thanks
Bo
try finding someone with a nandroid backup? and maybe check if you can use someone elses i am not sure if you can.
Or, try booting into recovery (holding down volume as you turn it on) and selecting factory reset
