What do you mean, "stuck in bootloader"?
You mean when you just straight put in the battery, the phone boots into the actual bootloader, where it says it's ready to accept a flash image?
What is actually happening when you insert the battery? Do you get the Droid red eye? If so, you need to insert the battery and QUICKLY hold the power + home buttons, then when the little android dude appears, hit the search button, scroll down to factory wipe and hit okay.
thanks anyways, once in a while it will boot into the M logo and stuck there as well..... I guess it needed to be returned.Very odd. Sorry, you're out of my knowledge base now - I can't imagine why it seems to be permanently booting directly into the bootloader. I guess I'd probably pull the battery and wait a couple minutes, then pop it back in and hold power + home to try and interrupt it.
