Okay, I did a search and found no information on a similar situation. Here's what happened. I recently rooted via unrevoked 3.21, then flashed a stock rooted rom, by OMJ, his most recent ROM. I ran the phone for a day with that ROM and kernel that it came with, and everything was working good, battery life seemed good for the day. Well, I decided to flash the 4.19 netarchy kernel this evening, and after doing so, the phone got stuck in bootloop, and I had to do a battery pull. TO flash the kernel, I did this : flashed from clockwork recovery to RA 1.8. Wiped cache, wiped dalvik cache, flashed kernel from SD card, rebooted phone. Then it was just stuck in bootloop, endlessly rebooting. I pulled battery after about 25 minutes, and rebooted into Recovery, which was RA at this point. I wiped all data, cache, davlik. flashed the OMJ ROM again, flashed the netarchy kernel, rebooted. same thing. Pulled battery again, rebooted to recovery, wiped data, cache, davlik. Flashed ROM, no Kernel this time. Booted fine. went into ROM manager, flashed back to clockwork. booted to recovery. wiped data, cache, davlik. restored nandroid backup from earlier today. That is where I'm at now, my EVO is back to the way it was a couple hours ago, which is sweet. (sorry for spelling it out, but figure the more info about what I did, the easier it will be for someone to help me) So I'm wondering what to do now, or if I did something wrong while flashing the kernel. Should I just try a different one? I would still like to try a different kernel, i want to experience the fps uncapped. Thanks in advance for any help.
BTW: I thought i had read on here, that when flashing from clockwork to RA, via ROM manager, that after a reboot it would be back to clockwork. Is that incorrect? because after I flashed from clockwork to RA, it definitely did not boot back into clockwork, I had to flash clockwork again. Thanks
kyle
kyle
