Try pressing Volume Down, Power, and the Back buttons within a second of each other and hold them till your Admire reboots in to recovery mode. Once there, use the Volume buttons to select Factory Reset and press the home button to select it. Warning: This will delete EVERYTHING on you Admire. If that doesn't do anything, maybe one of the more experienced people here will explain how to boot into recovery and flash a stock ROM and blah blah blah...
