Help Help! Sudden popup message making unuseable; MUST have phone before work!
I have a Virgin s2. I just have original stock rom, Ive done nothing at all to it. I changed out my batteries, turned it on, then after it got loaded I got a popup saying "unfortunately the process com.android.phone has stopped"! I restarted then as soon as i tried to do something, i recieved it again. I restarted again & didnt get message til I had opened google & was waiting for search results to come up when I got message saying something about couldnt find a mobile network (or something like that), then got the "unfortunately the process....." popup. Now it pops up over & over, including when I got a phone call (which made it impossible to answer, however I was able to call them back okay). Please Help! I must have phone & internet for work in morning!
Thank you for your time & assistance.
SOLVED (I hope):tee:
Went ahead & just backed up contacts to sd card, then did a Reset through Recovery. So far no "Unfortunately the process com.android.phone has stopped" message.:dancing2:
Thanks for letting us know that you've solved the problem. Fingers crossed it stays fixed! :D
