Root help suggestions on battery!!!
YamiR6
Member
hey guys last night i updated all my apps on the market. Well today my battery has been draining drastically. I have wiped the cache delvik and reinstalled my rom and theme and still nothing. I don't know what to do about getting it back to normal how it was. any suggestions?
Well the first thing would be to view the system resource, so check your cpu usage and memory usage. You can tell if something is consuming alot of resource more than it should if you updated the app and you would know how much its normally used. Now this can happen for few reason could be memory leak or battery is not fully calibrated which I doubt as you didn't discharge it.
