Root help Swapping internal external sd card bricked my phone
stevestone
Hello,
I tried using ryanb876 method to swap internal to external sdcard, but after reboot i ended up with errors.
unfortunately, the process android.process.media has stopped.
with some other errors, gapps stopped.. any many application not working..
I see no internal and external are mounted. I tried to cleared cached but it doesnt worked. Even tried data and cache wipe from recovery doest worked.
I tried to restore vold.fstab from root explorer and then to same error. please help... :(
but i can use adb...
