Help Tablet from China
meofibra
good
Tou need help I bought a tablet china CyberNav Mini: Android Tablet PC GPS Satellite 5 y ", WiFi, Multi (CVXC-TR39) centraltronics.com this site and was quick to give up after 1 month and a half the tablet stopped work do not know what happened but it turns the screen is starting (Android) is nothing anyone can give me help??
info do tablet
Ficha Tecnica de la Tablet PC
GENERAL:
# Sistema Operativo: Google Android 2.2 Froyo
# Procesador: infoTmic ARM11 1GHz + HD video codec + 3D graphic accelerator
# Pantalla: Pantalla Tactil de alta calidad, de 5" (12.5cms)
# Bateria: Recargable de Lithio (1500mAh)
# Idiomas Disponibles: Espa
good
Have you tried performing any percussive maintenance? It's probably broken though, usual story with these things. Have you tried resetting it, if possible? Send it back, hopefully it's under warranty.
I tried to send garatia but as I sent a box of junk I had no tablet to garatia but he did not fall I've been installing some themes desligei then reconnected it after he was well
