You hit customize or Advanced and hit the confirm button
43hrs 49min uptime today and i have 12% left
49hrs @ 6% @9:31pm Central US
very weird... ever since saturday my battery life has changed.. usually i lose 3-4% per hour completely idle, which was fine for me.. however yesterday and today i dont even lose 1% now! it's been 3.5 hours granted my phones just been sitting there, i only made 1 call and its still 100%. I have no idea what changed, actually the only thing different is that JD isn't on anymore, hmm................
Uptime: 61 hours and counting!
Yeah try to get rid of it make sure u clear the App cache and redownload. I would honestly get Ultimate Juice because that is the only way to really edit the settings like i have them the free one does not let you fine tune this much.
Hate to say but maybe even a factory reset because that seemed to have boosted the shit out of my battery life.
I am running the Froyo we got a little while ago from Samsung. I was having some problems so I decided to do the three finger salute and Factory reset 3x and wiped the Cache 3x n start fresh. So far no problems. I used to have a few, the gallery would freeze, and texts would hang and not send or get stuck showing a new one is there when it is not. But that's all gone now.
And Startup auditor doesnt make a huge difference but it helps to have the DRM turned off a tiny bit so far for me its not a necessary app. It does however seem to boost start up time a bit.
App Cache is when you go to Menu > Settings > Applications > Manage Applications > Select the App then you will see: Force Stop, Uninstall, Clear Data, Clear Cache the last one is the App Cache (Clear Cache) I'm talking about.OK, so I know I sound like a complete idiot, but i am very new to Android....what is App Cache and how do I clear it?
The Three Finger Salute is shut down the phone completely then hold down at the same time Volume down + Power Button + Camera Button till you see Sprint the Now Network boot up graphic start. This boots the phone into recovery mode. Here is where you flash new roms or updates that can be downloaded. And also do cache wipes and factory resets too you use the volume up/down to scroll and the home button is Enter/OK.what is a "three finger salute"? Are you saying you did a factory reset three times? What is froyo?
