HELP! The LED Notification light stopped working!
Pacman
My light has stopped working.
The LED isnt dead, cos I DL'd Missed Call from the Market, and it works with that app, but not when I get a text, tweet or FB invite/msg/event.
It flashed green for: tweets and texts
and
Blue for FB notifications.
HELP me plz!
Why? Thats so stupid... Do I have to use the Missed Call App to get it going again?
(Thanks for answering to btw! :p)
:D
Why the hell did they take away the LED Flashing light. It was SOOOO convenient, i liked see that indicator cos i didnt have to make my screen UNSLEEP... And all together my LED Flash doesnt work. Any situation, it doesnt work. >.<
You will still get an icon in the notification bar at the top.
If you use Handscent you can customize icon colors and notification sounds for different individuals.
but which sub-forom?and which button should I click to go to the forum and create a new thread?Oh,forgive me,I found I'm so foolish
oooooooooohhhhhhhhhhhhhhhhhhh I get it now. my bad.
Sounds like a call to VZW to get it replaced but be forewarned, they are going to want you to do a factory reset first.
