my htc fell into the water have left it to dry 4 a couple of days now i try turning it on it dnt turn on,bt if i hold the power button down there is a blue light that flashs any help please!!!!!
You've probably had it to be honest. You can try taking the battery out and leaving both in a container of rice for a week to dry out but the damage will be done by now.
